Services
Single-Project Capability
Years Commercial Construction
Nationwide
Post-Commissioning Failures
📅 Q3 2026 booking now open | Call (346) 676 - COLD
Specialized facilities for every cold chain requirement
Custom cold rooms inside existing structures. Box-in-box construction with IMP envelopes, vapor barriers, and dedicated refrigeration.
USDA and FDA-compliant cold processing areas. Washdown-rated finishes, antimicrobial surfaces, and integrated HACCP-ready temperature monitoring.
We start with your product specs, throughput requirements, and site conditions. Our team engineers the thermal envelope, refrigeration load, and structural system before a single panel goes up.
Full system commissioning: every zone tested to spec, every seal verified, every compressor validated. We don’t hand over keys until the facility performs exactly as engineered.
Most projects fail before they start. Thermal bridging ruins efficiency. Delivery schedules become fiction. Commissioning = temperature inconsistencies. Cold chain doesn’t forgive. -10°F instead of -20°F = lost product, lost compliance, lost trust.
We built US Cold Storage Builders because cold storage engineering isn’t construction with refrigeration bolted on. It’s physics, precision manufacturing, and proven sequencing.
One contract. One point of contact. We self-perform insulated panel installation, manage all mechanical trades, and deliver a fully operational facility — not just a shell.
Insulated metal panels are the #1 failure point in cold storage. We specify, source, and install IMP systems rated for your exact temperature range and climate zone.
Our team has delivered 100,000+ SF in a single cold storage project. We understand refrigeration loads, vapor drive, frost heave prevention, and sub-zero commissioning.
Based in Houston with project capability across Texas and the US. Licensed, insured, and equipped for cold storage construction in any climate zone.
Your Cold Storage Project Starts Here
“They delivered our 40,000 sq ft freezer facility on time and under budget. The team knew exactly what a food-grade cold storage needed — we didn’t have to explain anything twice.”
JR
James R.
Director of Operations · Texas Food Distributor
Services
❄️ Cold Storage
🧊 Blast Freeze
🏗️ New Build
🔧 Retrofit
🌡️ Multi-Temp
💊 Pharma-Grade
📦 3PL Warehouses
We respond within 1 business day
Get in touch with us
Cold storage construction typically ranges from $120 to $300 per square foot depending on temperature requirements, size, and complexity. Frozen storage (-20°F and below) costs more than refrigerated (28–45°F) due to thicker panel systems, heavier refrigeration loads, and frost heave prevention. We provide detailed project estimates after an initial consultation.
Most projects run 6 to 14 months from design to commissioning. The timeline depends on facility size, permitting, and equipment lead times. Insulated panels currently have 12–16 week lead times, and refrigeration equipment runs 16–24 weeks. Early planning significantly reduces overall project duration.
Yes. We manage the full process — structural engineering, MEP design, permit applications, inspections, and final certificate of occupancy. One contract covers everything from site prep to commissioning.
We build facilities ranging from +55°F coolers down to -40°F blast freezers. Multi-zone facilities with independent temperature control in each room are our specialty — our We Store Frozen project has 5 independent sub-zero rooms under one roof.
Yes. Box-in-box retrofits install insulated metal panel envelopes inside existing structures. This includes vapor barriers, new refrigeration, upgraded electrical, and frost heave prevention for the existing slab. Retrofits typically cost $80–$160 per square foot.
Yes. We’re based in Houston and serve all of Texas, with project capability nationwide. Our team has experience with climate-specific requirements across multiple states.
Frozen storage construction requires specialized engineering that fewer than 5% of commercial GCs can deliver. Our build calendar fills 6+ months ahead. Secure your project timeline before the next available window closes.
EQUIPMENT LEAD TIMES
When a Houston distributor needed a 100,000 square-foot frozen facility built around specific throughput requirements, they called us. Tell us what you need — we’ll engineer
around it.
